Question: Buchberger function same as Basis function then how to make it as solver function?
is it the newly added y(y-1) be used in solver to find x ?
i find eliminate without y*(y-1) same solution as adding y*(y-1)
why premas and Reduce are different for calculating remainder h?
where is wrong in commented L and S polynomials ? LCM wrong?
with(Groebner):
with(ListTools):
with(combinat):
premas := proc(P,A, PRing)
local R, i, x;
R := P;
i := nops(A);
while i <> 0 do
 x := MainVariable(A[i], PRing);
 R := prem(R, A[i],x);
 i := i - 1:
od:
return R:
Buchberger := proc(Fparam, PRing)
#Fparam := [x*y-x, -y+x^2]:
F := MakeUnique(Fparam):
GG := choose(F, 2):
G := F:
while GG <> [] do
f := GG[1][1]:
g := GG[1][2]:
GG := [seq(GG[i], i=2..nops(GG))]:
#L := lcm(TrailingTerm(f, PRing)[2],TrailingTerm(g, PRing)[2]):
#S := simplify(L/LeadingTerm(f, PRing)[2]*f - L/LeadingTerm(g, PRing)[2]*g);
S := SPolynomial(f, g, PRing);
#print("S",S);
#print("G",G);
# S reduce to G modulo h
#h := premas(S, G, PolynomialRing([x, y, z]));
h := Reduce(S, G, PRing, 'h');
#print("h",h);
if h = 0 then
h := []:
end if:
if h <> [] then
 GG := [op(GG), [SelectFirst(G), h]]:
 G := [op(G), h]:
end if:
od:
return G:
sol := Buchberger([x*y-x, -y+x^2], plex(x, y));
factor(sol[nops(sol)]);
eliminate(sol,[x,y]);
eliminate([x*y-x, -y+x^2],[x,y]);
sol := Basis([x*y-x, -y+x^2], plex(x, y));
solve([x*y-x, -y+x^2]);
