Question: How can I reduce timing to get the result of this code?
I want to find the numbers a, b, c, d, t, m, n of this equation. I tried
 k := 0:
 for a to 10 do
for b to 10 do
for c to 10 do
for d to 10 do
for t to 2 do
for m to 10 do
for n to 10 do
if a > c and igcd(a, b, c, d, t, m, n) = 1 and abs(b)+abs(d)-n <> 0 then X := [solve(abs(a*x+b)+abs(c*x+d)-t*x^2+m*x-n = 0)]; if nops(X) = 6 and type(X[1], integer) and type(X[2], integer) and type(X[3], integer) and type(X[4], integer) and type(X[5], integer) and type(X[6], integer) then k := k+1; L[k] := [a, b, c, d, t, m, n, X[]]
end if end if
end do end do end do end do end do end do end do;
L := convert(L, list);
k;
L;
I can not get the result for along time. How can I get the result and reduce the time?
