Question: Task programming model - Problem with array numelems
Dear friends, please I would like to ask for your help with the following problem:
I need to invoke the number of elements of an Array working with parallel programming in the task programming model. I've tried to used the command rtable_num_elems as it is contained in the thread safe functions lists. However, Maple does not recognize it as I obtain the error "Bad index into array". Using the same code, I've substituted the array for a list and rtable_num_elems for nops and the code works perfectly. What could I be doing wrong? I need to use arrays given the extension of the data I'm handling.
Many thanks for your kind help.
