Question: A general Step Function not with the right plot
A complicated programmed task for me
I must analyze this
In this plot there are vertical  walls connected with the step area's , but that its not wanted.
Also the domain is showed by adding 0 in the plot 3d( {0, 'g(x,y)'}, ...) and this distract the plot with the step area's
Its not needed the domain in the plot ( in order to get the 0 value for z )
The 3 axis x,y,z  are not visible in the plot
Seems to be not complete programmed as it just to be.
f:=proc(A,B,T,x,y)
     local n,m,i,j,val;
     n:=nops(A);m:=nops(B);
       for i from 1 to n-1 do
         for j from 1 to m-1 do
         if (A[i]<=x and x<A[i+1]) and
            (B[j]<=y and y< B[j+1]) then val:=T[i,j];
         end if;
          end do;
       end do;
     val;
A:=[0,1,2];B:=[0,1,2];T:=array([[1,2],[1.5,1]]);
A := [0, 1, 2]
B := [0, 1, 2]
array( 1 .. 2, 1 .. 2, [( 2, 1 ) = (1.5), ( 1, 1 ) = (1), ( 2, 2 ) = (1), ( 1, 2 ) = (2)  ] )
g:=(x,y)->f(A,B,T,x,y);
proc (x, y) options operator, arrow; f(A, B, T, x, y) end proc
plot3d({0,'g(x,y)'},x=0..2,y=0..2,axes=normal,
           scaling=constrained,orientation=[-37,75],
           projection=0.8,tickmarks=[3,0,2],
           shading=XYZ,lightmodel='light3');
Download texc_set_4_-task_3_-forumvraag.mw
