Question: A threadsafe procedure to count the number of solutions from PolynomialSystem
Hello
I need to check if the solution (sols) of a (nonlinear) polynomial system of equations (the coefficients are not numeric) has only one solution for, let's say, y and (one solution for y and one solution for z).  I cannot use allvalues (not threadsafe according to CodeTools:-ThreadSafetyCheck) and then count the number of solutions.
I have removed all solutions that fit the command
ormap(x->x=true,map(has,rhs~(op~(sols)),_Z))
(RootOf works too).  (Please tell me if I am using ormap correctly).
Even using the above command and then checking if nops(sols)=1, not all one solutions are caught.
Many thanks
Ed
