Question: How do I simply an expression into simpler variable
Is there any way we could use Maple to simplify an equation,
Example: M= 2pqrst / uvw
I would like a code or a way to separate some variables into one variable, where the expression would be M = 2Krst / w
which can be said that K = pq / uv
I know that I can use the simplify command but it's only worked for simpler expression but not complicated one.
Really need help from you guys.
Thank you :)
