Question: how to make Typesetting use typesetprime=true for all variables?
I am learning Typesetting so I can get better Latex.
I'd like to have all derivatives generated as y'(x) and not dy/dx regardless of what the derivative variable is. (It is more clear this way).
I found I can't even give Maple a list of the variables. But must do it each time one at a time.
I have thousands of ODE's I need to typeset, (they use different variables (depending on the textbook), and not always x or t, but the set of variables is not large).
so having to check and keep changing this setting each time is awkward (but I think is doable, as I know what the independent variable is for each ode so I can call Typesetting at start of each ode processing, once I know what the variable is).
It wil be much easier if there is a way to tell Maple to do this for all variables. May be there is a good reason why Maple does not seem to allow such an option?
Here is an example
Typesetting:-Settings(usedot=false,prime=t,typesetprime=true):
ode:=diff(y(t),t$2)+diff(y(t),t)+y(t)= 0:
Physics:-Latex(ode);
Which gives the Latex I want
But if the variable was x instead of t, I have to do this
Typesetting:-Settings(usedot=false,prime=x,typesetprime=true):
ode:=diff(y(x),x$2)+diff(y(x),x)+y(x)= 0:
I tried doing prime=[x,t] but Maple did not like this.
Is there a way or trick to tell Maple to use typesetprime=true for any letter?  I looked at https://fr.maplesoft.com/support/help/Maple/view.aspx?path=Typesetting%2fSettings but do not see a way so far.
Maple 2020.1 with Physics 776
