Question: which sample points are correct and how to generalize this CAD and how to calculate projection with maple?
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Original question is find CAD of (some y)[P1 <0 and P2 <0]
how to use maple 12 and maple 2015 to find Q1,Q2,Q3 which are projection of P1 and P2
my book show sample points are [-4,-1-sqrt(7),-3,-2,0,1,3/2,-1+sqrt(7),9/5,2,3]
but FindSamples result is not the same with my book, is it my book wrong or FindSamples function wrong?
I find result of my script is the same as book's quantifier position at 7,8,9 though sample points has little different
how to generalize my following script to multiple variables x, y, z, and more ?
and
I compare with maple 2015 result are different from my book solution, is maple 2015 more advanced version CAD?
with(ListTools):
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Q1 := x^2 + 2*x - 6;
Q2 := x^2 - 4;
Q3 := x - 1;
sourcesamples := sort(evalf([solve(Q1), solve(Q2), solve(Q3)]),`<`);
FindSamples:=proc(sourcesamples)
local N, P;
N:=nops(sourcesamples);
P:=proc(a,b)
local a1, b1, m1, n, m;
if a=b then error "Should be a<>b" fi;
a1,b1:=op(convert(sort([a,b],(x,y)->evalf(x)<evalf(y)),rational));
count := 0:
for n from 1 do
m1:=a1*n;
m:=`if`(type(m1,integer),m1+1,ceil(m1));
count := count + 1:
if is(m/n>a1) and is(m/n<b1) then return m/n fi;
od;
print("count=",count);
[ceil(sourcesamples[1])-1, seq(op([sourcesamples[i],P(sourcesamples[i],sourcesamples[i+1])]), i=1..N-1),sourcesamples[N],floor(sourcesamples[N])+1];
RemoveComplex := proc(yy)
local result, k:
result := []:
for k in yy do
if Im(k) = 0 then
result := [op(result), k]:
end if:
od:
if result = [] then
result := []:
end if:
return result:
Joinsolution := proc(param1, param2group)
local result, k:
result := []:
for k in param2group do
result := [op(result), [param1, k]]:
od:
return result:
CADsamples := FindSamples(sourcesamples):
CADresult1 := []:
for mm in CADsamples do
#print(mm):
if MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))])) = [] then
CADresult1 := [op(CADresult1), op(Joinsolution(mm,[0]))];
else
CADresult1 := [op(CADresult1), op(Joinsolution(mm,FindSamples(sort(evalf(MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))]))),`<`))))];
end if:
od:
CADresult1;
for mm in CADresult1 do
if subs(x=mm[1],subs(y=mm[2], P1)) < 0 and subs(x=mm[1],subs(y=mm[2], P2)) < 0 then
print("solution ", mm, SearchAll(mm[1],CADsamples), evalf(mm)):
end if:
od:
Compare with
with(RegularChains):
with(ChainTools):
with(MatrixTools):
with(ConstructibleSetTools):
with(ParametricSystemTools):
with(SemiAlgebraicSetTools):
with(FastArithmeticTools):
R := PolynomialRing([x,y]):
sys := [x^2+y^2-4,y^2-2*x+2]:
N := []:
P := []:
H := [x]:
dec := RealTriangularize(sys,N,P,H,R):
proj := Projection(sys, N, P, H, 1, R);
Display(dec, R);
P := SamplePoints(sys, R);
Display(P, R);
cad := CylindricalAlgebraicDecompose(sys, R);
