Question: How to numerically solve a system of linear ODEs with an external, tabulated source?
Dear Community,
I have a four compartment flow model described with the following system of linear ODEs:
diff(L[1](t), t) = L[2](t)/T[21] - L[1](t)/T[12]
diff(L[2](t), t) = L[1](t)/T[12] - L[2](t)/T[21] + L[3](t)/T[32] - L[2](t)/T[23] + Q(t)
diff(L[3](t), t) = L[2](t)/T[23] - L[3](t)/T[32] + L[4](t)/T[43] - L[3](t)/T[34]
diff(L[4](t), t) = L[3](t)/T[34] - L[4](t)/T[43]
(For easier readability I’ve also described the problem in the attached FourCompartmentModelDescription.docx Word file.)
The time constants are as follows:
T12 = 23.1481 d
T21 = 5.4537 d
T23 =  9.752 d
T32 = 14.9007 d
T34 = 8.8235 d
T43 = 363.7255 d
Initial conditions are as follows:
L1(0) = 2500.
L2(0) = 589.
L3(0) = 900.
L4(0) = 37100.
Simulation should run from 0 to 400 d.
Could you pls. help me, to solve it numerically in Maple? As a solution I would need L1(t), L2(t), L3(t) and L4(t) both numerically and graphically. I used Maple to solve ODEs previously, but this time I don’t know, how to correctly specify the problem with an external, tabulated source. I’ve also prepared and attached a Maple worksheet, but did not try to run it yet. (FourCompartments.mw). The external Q(t) source for compartment 2 is attached as Source.xlsx. Should I've forgotten something, pls. let me know.
Your kind help is appreciated in advance,
best regards
Andras
MaplePrimesFourCompartmentModelDescription.docx
FourCompartments.mw
Source.xlsx
