Question: I encountered an error"initial Newton iteration is not converging" when solving an ODEs with dsolve. How to overcome it by a simple way?
Hi, I'm solving a complicated ODEs. It is a multiple point bvp. Last time I asked a question about a similar problem(you can see https://www.mapleprimes.com/questions/230626-I-Am-Trying-To-Solve-A-Set-Of-ODEs-With). And when I use the last point 's solution to obtain the next point's solution (via approxsoln=..), it works well (it's the replicate of other people's paper). But this time I changed theoretical model, so the input parameters and the equations are some different from the previous. Some problems appears again. In the code I used a loop to calculate solutions with different lambda, but the code works on some points in front, then it appears an error "initial Newton iteration is not converging".
Do you have some ideas to overcome it?
dsolveODEs.mw
