Question: why can't Maple decide if 2+89^(1/2)>0 ?
Any idea why
if 2+89^(1/2)>0 then
   print("yes");
else
   print("no");
fi;
gives
Since
evalf(2+89^(1/2))
is 11.4339.
I tried in Mathematica, and it works there
If[2 + 89^(1/2) > 0, Print["Yes"], Print["No"]]
What is the correct way to do this in Maple? i.e. to check that a numerical value is >0 ?
This is done in code, where the value I am doing this check on are known to be numeric, but I do not know what form they will be, I just know they will contain no floating point numbers. Only exact numbers.
The problem is the 89^(1/2). Maple knows it is >0
is(89^(1/2)>0)
        true
but
if (89)^(1/2)>0 then
   print("yes");
else
   print("no");
fi;
May be because 89 is prime. Should I replace my if with is for this check?
interface(version)
Standard Worksheet Interface, Maple 2020.1, Windows 10, July 30
   2020 Build ID 1482634
Physics:-Version()
The "Physics Updates" version in the MapleCloud is 867 and is
   the same as the version installed in this computer, created
   2020, November 12, 9:14 hours Pacific Time.
