Question: why setting warnlevel makes dsolve give different form of the solution?
why setting interface(warnlevel=0); makes dsolve change the form of the final solution to an ODE?
Is this to be expected? Help on warnlevel 0 says to just suppress all warnings
In this example, both solutions are equivalent. One is just simpler than the other.
But now I am worried if this setting could affect dsolve in other ways not yet anticipated.
`Standard Worksheet Interface, Maple 2020.2, Windows 10, November 11 2020 Build ID 1502365`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 884 and is the same as the version installed in this computer, created 2020, November 25, 16:49 hours Pacific Time.`
3
ic:=y(0)=3:
ode := diff(y(x),x)*y(x)/(1+1/2*sqrt(1+diff(y(x),x)^2))=-x:
sol_1:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(1/3)*(-9*x^2+324)^(1/2), y(x) = 1+(1/3)*(-9*x^2+36)^(1/2)
ic:=y(0)=3:
sol_2:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(-x^2+36)^(1/2), y(x) = 1+(-x^2+4)^(1/2)
Download warnlevel_difference.mw
btw, the same thing happens with warnlevel 2. i.e. answers look different.
But with warnlevel 3 and 4, now dsolve gives the same answer.
SInce it seems default is warnlevel 3, it seems internally, dsolve takes different path depending on warnlevel setting?
Edit
Here is a movie. I am using windows 10.
Edit: Here is another video. Tried now with fresh start of Maple. i.e. closed Maple and started it again.  Using worksheet. No other worksheet was open. This is what I found. Initially it gives the longer solution. After couple of tries, it then changed to the simpler one
