Question: Find/Replace operation in a worksheet with code edit regions
Hello everyone,
I have a problem when searching in a document. Namelly is there a way to search in the whole worksheet including all code editing regions?
In order to show a point, there is a worksheet. I determine a variable
x11:= 12;
This variable is used in the document and code edit regions. Then I want to change a variable name from x11 to x11data. In order to do that, I use Ctrl+F to find all the times when the variable is used. I have a problem while  searching 'x11'. Namelly, the cases outside a code edit region are displayed, and the ones that are situated in the code edit regions are not seen.
Best regards
