Question: why odetest does not verify this solution against IC?
I solved this ode with IC, and obtained a solution.  Maple odetest says my solution satisfies the ODE but not the initial conditions. But I do not see why. When I plugin manually the initial conditions into the solution, I get true.
So I am not sure what is going on.
ode:=x*diff(y(x),x)*y(x) = (x+1)*(y(x)+1);
ic:=y(1)=1;
mysol:=y(x)-ln(y(x)+1)=-ln(2)+x+ln(x);
my_sol_at_IC:=subs([y(x)=1,x=1],mysol);
#now check manually
evalb(my_sol_at_IC);
is(my_sol_at_IC);
Using odetest gives
odetest(mysol,ode);
odetest(mysol,[ode,ic]);
What Am I doing wrong?
Maple 2021.1
Edit June 12, 2021
This is another example where odetest gives different result depending on how the solution is written !
ode:=diff(y(x),x)=2/3*(y(x)-1)^(1/2):
mysol_1:=y(x) = 1/9*x^2 - 2/9*x + 10/9:
mysol_2:=y(x) - (1/9*x^2 - 2/9*x + 10/9) = 0 :
odetest(mysol_1,ode);
odetest(mysol_2,ode);
