Question: How to pkill or kill mserver when using Grid?
I rewrite my code with Grid library using local vCPU of amazon
discover no license of distributed HPC when setup command show need go to acresso.com
can Grid still be used and function with local 96 number of vCPU?
then when I test code, I can not pkill mserver in ps -aux in LInux
can the performance really improved ? Because I suppose 3 to 5 minutes mserver will end and disappear from ps -aux but grid node of mserver still running
originally I can run 100 batches every day., but I have to monitor decrease of memory in order to determine whether can kill mserver for next batch
I expect run 400 batches per day. But Can not kill mserver when using grid
In my code I had using time limit(30, ...)
when using Grid seq of function , can lprint work normally to get results into text ?
i notice Grid up to 57, do I need to recalculate and revise code to fit 96 vCPU for grid number 96?
