Question: Using Syrup, how to call or use a circuit element as a variable with its assigned value in a subsequent calculation?
After I define a Ckt (a ladder network) such as :
Ckt := [v1(4), R1(50) &+ L2(0.9600), Cp(0.8200), L1(0.5000) &+ R2(0.2000), RL(1.3430) &+ LL(0.1550)]
How would I then use the value of R1 as defined above, for example, in a subsequent calculation?
Assuming the results from Solve are in (sol,rest), how can I use R1 (defined in Ckts)as a variable  --something like:
P_R1_ave := (abs(eval(v[R1], rest))/sqrt(2))^2/Ckt[R1]
t-match_impedance.mw
BTW, I can no longer "insert contents" .  I get the following error:
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/t-match_impedance.mw .
I have no idea what may have changed --perhaps something on our server?
