Question: problems with revolutions, radians, RPM Units, rotational speed
simplified_MPH_to_RPM_to_engineering_units.mw
Good Morning,
I don't know why I have such difficulties with rotational units, esp the 2*pi conversions with radians and revolutions.
   We are often back solving from MPH of the vehicle back to RPM of the wheel (revolutions per minute [or seconds]) to Rad/sec for engineering units such as torque*RPM calcs for power - kW.
Almost everytime I try to use units to convert the units the worksheet will revert to "atomic" units.   I quote "atomic" as this is what I appears to be.:  See graphic (also simplifiied worksheet attached)
The unit length(radius) seems to be a factor that is not well documented.   It also seems the earlier rplies include extra work to use convert and possibly "symbolic = true") as an extra step per Acer in an earlier posting several years ago.
When running calcs the convert, or simplify (to cancel length units m and inches out) the cancelations and the unit combinations seem to work awkwardly in this particular area.
