Question: Can I change RK45 into RK4?
Dear All, If I understood well dsolve uses the RK45 method to solve an ODE. I would like to compare the results of tha attached worksheet with the results of another software that uses RK4 as a standard. Can I adapt my worksheet to use RK4 and how do you do that? Thanks in advance for your willingness to help me out.QMP_Nov21.mw
