Question: Re: How to treat differentiaion operator as a coefficient
Hello all,
Would you allow me to ask this one question?
[moderator: See also this previous question]
Is there any possible way to treat the differentiation operator (e.g., 'D') as an ordinary coefficient of a polynomial?
For example, as described in the attached worksheet, I was wondering if there is a way to re-write the LHS of the expression 'eq_e5_9b' as the expression 'desired'.
In Kwon Park
with(DEtools):
eq_e5_9b := psi__d0*Delta__delta(t) + psi__q0 * D(Delta__delta(t))/omega__0 = p_(Delta__psi__d(t))/omega__0 - Delta__psi__q(t);
psi__d0*Delta__delta(t)+psi__q0*D(Delta__delta(t))/omega__0 = p_(Delta__psi__d(t))/omega__0-Delta__psi__q(t)
collect(lhs(eq_e5_9b), Delta__delta(t));
desired := Delta__delta(t) * (psi__d0 + psi__q0 * D/omega__0);
Delta__delta(t)*(psi__d0+psi__q0*D/omega__0)
Download Q20220404.mw
