Question: Can Maple's functions be packaged as executable files?
The problem comes from the link https://www.mapleprimes.com/questions/234398-Convert-Maple-Code-To-Python-#comment287424.
We know that when we compile a C or C ++ function, it generates an executable file.  Then we are free from source code.  For example. the function below returns a square matrix A where    "A[i, j]" is the distance from vertex i to vertex j in the graph G. My computer system is Windows.
// C Program for Floyd Warshall Algorithm
#include <stdio.h>
// Number of vertices in the graph
#define V 4
/* Define Infinite as a large enough
  value. This value will be used
  for vertices not connected to each other */
#define INF 99999
// A function to print the solution matrix
void printSolution(int dist[][V]);
// Solves the all-pairs shortest path
// problem using Floyd Warshall algorithm
void floydWarshall (int graph[][V]) {
    /* dist[][] will be the output matrix
      that will finally have the shortest
      distances between every pair of vertices */
    int dist[V][V], i, j, k;
    /* Initialize the solution matrix
      same as input graph matrix. Or
       we can say the initial values of
       shortest distances are based
       on shortest paths considering no
       intermediate vertex. */
    for (i = 0; i < V; i++)
        for (j = 0; j < V; j++)
            dist[i][j] = graph[i][j];
    /* Add all vertices one by one to
      the set of intermediate vertices.
      ---> Before start of an iteration, we
      have shortest distances between all
      pairs of vertices such that the shortest
      distances consider only the
      vertices in set {0, 1, 2, .. k-1} as
      ----> After the end of an iteration,
      vertex no. k is added to the set of
      intermediate vertices and the set
      becomes {0, 1, 2, .. k} */
    for (k = 0; k < V; k++) {
        // Pick all vertices as source one by one
        for (i = 0; i < V; i++) {
            // Pick all vertices as destination for the
            // above picked source
            for (j = 0; j < V; j++) {
                // If vertex k is on the shortest path from
                // i to j, then update the value of dist[i][j]
                if (dist[i][k] + dist[k][j] < dist[i][j])
                    dist[i][j] = dist[i][k] + dist[k][j];
    // Print the shortest distance matrix
    printSolution(dist);
/* A utility function to print solution */
void printSolution(int dist[][V]) {
    printf ("The following matrix shows the shortest distances"
            " between every pair of vertices \n");
    for (int i = 0; i < V; i++) {
        for (int j = 0; j < V; j++) {
            if (dist[i][j] == INF)
                printf("%7s", "INF");
            else
                printf ("%7d", dist[i][j]);
        printf("\n");
// driver program to test above function
int main() {
    /* Let us create the following weighted graph
            10
       (0)------->(3)
      5 |          |
        |          | 1
       (1)------->(2)
            3           */
    int graph[V][V] = { {0,   5,  INF, 10},
        {INF, 0,   3, INF},
        {INF, INF, 0,   1},
        {INF, INF, INF, 0}
    // Print the solution
    floydWarshall(graph);
    return 0;
The above functions will be packaged as the disall.exe , and then we will move them anywhere in my computer and run it in Powershell.  We don't have to deal with the source code unless we want to change it.
I mean can Maple do something like that?
with(GraphTheory);
G := Graph([1, 2, 3, 4, 5], {{1, 2}, {1, 3}, {1, 4}, {1, 5}, {2, 3}, {2, 5}, {3, 4}, {4, 5}});
AllPairsDistance(G);
For exmaple, can I package the above code snippet into an exe file?
