Question: How can I attach labels to LP solution matrices and produce a network flow diagram from the solution?
Good day.
I am working on a network flow problem that uses a linear programming (simplex) technique.The flow is directed across 3 regions (a, b, and c) and there are 2 nodes within region a, 4 nodes in region b, and 5 nodes in region c.
I wish to determine the minimum cost from regions a to c and from regions b to c that satisfies the requirement of each of the 5 nodes in region c. The objective and constraints are constructed and Maple produces the minimum solution (see attached). While the output is useful when the number of nodes is small, I would like to extend this to a larger-scale case and so the output would need to be more user-friendly / graphic.
I have 2 questions -
1. Does anyone know a way to attach labels for each region and each node to these solution matrices?
    For instance -  the first matrix, x, specifies a quantity of 2,000 that flows from node #1 in region a to node #2 in region b
2. Is it possible to produce a network graph showing the directed flow from each region and from node to node?
Thanks to all for reading this!
MaplePrimes_Network.mw
