Question: Non-Linear System, fsolve fails to find a solution
Non-Linear.mw
Hi, I have here a interesting non-linear system.
If I attempt to solve it using some specific form of the non-linear equations (form X*Y=Z) of the system, Maple (Verison 18) finds a solution.
But, if I replace some of them by some other forms (like form Y=Z/X), fsolve fails.
I usually use the non-quotient form. But is there any way to guide or configure fsolve to reach a solution?
I set up some of the regular options: placing a seed close to the solution, indicating intervals of possible solutions; but none of that works if I do not set up the non-quotient form of the equations. In some cases, fsolve does not reach a solution at all, no matter the form of the equations.
In the file, the equations that are causing the isssue are the last 3, those who start with the variable f1,f2 and f3.
I ran the system twice with both cases: non-quotient form and quotient form.
Thanks for your attention!
