Question: fsolve is not working
Hello Everyone;
Hope you are fine. I need to solve the system of equation. I am using fsolve command but it is not working. Kindly guide me.
ques.mw
Eq[0, 0] := 1.33120000000000000000000000000*lambda[0, 1]+1.33120000000000000000000000000*lambda[0, 2]+1.33120000000000000000000000000*lambda[0, 3]+1.33120000000000000000000000000*lambda[0, 4] = .916487142969312002551492271668:
Eq[0, 1] := 1.32901933598375616624661615670*lambda[0, 1]+1.32901933598375616624661615670*lambda[0, 2]+1.32901933598375616624661615670*lambda[0, 3]+1.32901933598375616624661615670*lambda[0, 4] = 1.09232395220587507357427365904:
Eq[0, 2] := 1.37120000000000000000000000000*lambda[0, 1]+1.37120000000000000000000000000*lambda[0, 2]+1.37120000000000000000000000000*lambda[0, 3]+1.37120000000000000000000000000*lambda[0, 4] = 1.25415129307905065856083635281:
Eq[0, 3] := .966980664016243833753383843299*lambda[0, 1]+.966980664016243833753383843299*lambda[0, 2]+.966980664016243833753383843299*lambda[0, 3]+.966980664016243833753383843299*lambda[0, 4] = 1.37114174964252179339832329224:
fsolve({seq(Eq[0, ii1], ii1 = 0 .. 3)});
fsolve({.966980664016243833753383843299*lambda[0, 1]+.966980664016243833753383843299*lambda[0, 2]+.966980664016243833753383843299*lambda[0, 3]+.966980664016243833753383843299*lambda[0, 4] = 1.37114174964252179339832329224, 1.32901933598375616624661615670*lambda[0, 1]+1.32901933598375616624661615670*lambda[0, 2]+1.32901933598375616624661615670*lambda[0, 3]+1.32901933598375616624661615670*lambda[0, 4] = 1.09232395220587507357427365904, 1.33120000000000000000000000000*lambda[0, 1]+1.33120000000000000000000000000*lambda[0, 2]+1.33120000000000000000000000000*lambda[0, 3]+1.33120000000000000000000000000*lambda[0, 4] = .916487142969312002551492271668, 1.37120000000000000000000000000*lambda[0, 1]+1.37120000000000000000000000000*lambda[0, 2]+1.37120000000000000000000000000*lambda[0, 3]+1.37120000000000000000000000000*lambda[0, 4] = 1.25415129307905065856083635281}, {lambda[0, 1], lambda[0, 2], lambda[0, 3], lambda[0, 4]})
Download ques.mw
