Question: Problem with long description in a procedure
I have a long description that contains some Maple commands.
I dont want to use # as the lines dont show up when i use
Isee:=proc(a)
    interface(verboseproc = 3);
    printf("%P", eval(a));
end proc
The long description is. Any way around the problem?
Test:=proc(A,B,C)  description  "Computes projective line through 2 projective points or intersert of 2 projective lines as a projective point or coincidence of piont  line
 Does some checking on validity of inputs.
Mobposn:- Global Variable, must = 1 or 3.
Points are returned as <1,x,y> or <x,y,1>
 Lines are returned as <z,x,y> or <x,y,z>,
normalgpt :- Global Variable must be 0 or 1.
Points with algecraic elements are not reduced to <1,x,y> or <x,y,1> if 0
 Points are defined as row vectors and  lines as column `vectors"`;
 print(A,B,A-C);
 end proc;
