Question: How to select an undocumented name generated by RootOf or solve?
Even though this question is related to this one
https://www.mapleprimes.com/questions/234781-How-Can-I-Get-The-Desired-Answer-From-solve
feel it is about a different issue. If any of you feel otherwise feel free to move it to the original one.
In this notional example  the name _Z1~ is created by RootOf: and here is an ad hoc way to catch it.
f := RootOf(cos(x)-z, x):
u := indets(f, name);
s := series(f, z):
v := remove(type, indets(s, name), constant);
w := v minus u
{z}
{_Z1, z}
{_Z1}
Download Example_1.mw
In this more complex example an assumption must be made on M to obtain ths desired solution g and the previous method no longer works.
f := 10*cos((-1+t)/sqrt(1+M))-10*cos(t/sqrt(1+M)):
assume(M::nonnegative):
g := solve({diff(f, t), t>0 }, t, allsolutions)[1][1];
v := remove(type, indets(rhs(g), name), constant);
w := v minus u
{M, t}
t = Pi*_Z2*(1+M)^(1/2)-arctan((cos(1/(1+M)^(1/2))+1)/sin(1/(1+M)^(1/2)))*(1+M)^(1/2)
{M, _Z2}
{M, _Z2}
Download Example_2.mw
I have tried using select to "capture" the name _Z2~ but I can't know how to distinguish M~ from _Z2~ (is there a type which could be used?).
Can you helpm fix this?
TIA
