Question: Contour with different colors such the region above zero has same colors and region below zero has different set of colors
I want to change the colors of a contour such that the region above zero is represented by a different color instead of yellow color,  and that the colors for conts <0 are one set of colors (maybe yellow to red), and the area for which conts >0 is one color which is very different from the others (so maybe white).
Case4Contour.mw
