Question: CodeGeneration: How to force double?
I have started to use CodeGeneration[C] instead of codegen[C] (depreciated). In the attached example not all variables and parameters of a C function are declared as double, although the default value is double.
If this is by design:
How can I force double without going back to codegen[C] or manual declaration of each item?
C_code_generation_with_CodeGeneration.mw
