Question: Equations are acting inert
I have a matrix and generate difference tables from it's diagonals. Works fine. Then I make a polynomial from the first row of the difference table. I have three polynomials. They are all acting inert, just will not evaluate.
I cannot see what the problem is.
interface(rtablesize = 12)
[10, 10]
i) Recurrence relation
"Recurrence Relation for next column. . The matrix starts at 1,1 not 0,0 A(i,j)=A(i-1,j-1)*(j-2)+A(i,j-1)"
NULL``
Msize := 12
A := Matrix(Msize)
A[1, 1] := 1
for i from 2 to Msize do for j from i to Msize do A[i, j] := A[i, j-1]*(j-2)+A[i-1, j-1] end do end do
A
Matrix(%id = 36893489695842121836)
viia)  General formula for diagonals:-
Select diagonal  & Difference Table procedures
diag := proc (M::Matrix, dg::posint) local i, rd, c, dt; rd := LinearAlgebra:-RowDimension(M); dt := Matrix(rd, rd); for i from dg to rd do dt[1+i-dg, 1] := M[1+i-dg, i] end do; return dt end proc
diag(A, 5)
Matrix(%id = 36893489695866397388)
diftab := proc (M::Matrix) local i, j, cl, rd; rd := LinearAlgebra:-RowDimension(M); for i from rd by -1 to 1 do if M[i, 1] = 0 then rd := rd-1 else break end if end do; cl := rd; for i from 2 to cl do for j to rd-i do M[j, i] := M[j+1, i-1]-M[j, i-1] end do end do; print(M); return M end proc
diftab(diag(A, 4))
Matrix(%id = 36893489695866348116)
gnrpoly := proc (M::Matrix) local i, p, rd, n; rd := LinearAlgebra:-RowDimension(M); for i from rd by -1 to 1 do if M[1, i] = 0 then rd := rd-1 else break end if end do; p := 0; for i from 0 to rd-1 do p := p+M[1, i+1]*binomial(n, i) end do; return p end proc
"for i from 0 to 3 do print("Diagonal  ",i);   eqn:=gnrpoly(diftab(diag(A,i+1)));    cat(poly,i):=unapply(factor(expand(eqn)),n);    print("--------------------------------------------------------------");  end do"
The equations do not evaluate. They are acting inert
poly1(n)
(1/2)*n*(1+n)
poly1(2)
(1/2)*n*(1+n)
poly2(n)
(1/24)*n*(3*n+5)*(n+2)*(n+1)
poly2(3)
poly3(n)
(1/48)*n*(n+1)*(n+3)^2*(n+2)^2
poly3(-1)
eqn
6*n+38*binomial(n, 2)+93*binomial(n, 3)+111*binomial(n, 4)+65*binomial(n, 5)+15*binomial(n, 6)
value(eval(eqn, n = 4))
eqn1 := expand(eqn)
(3/4)*n+2*n^2+(97/48)*n^3+(47/48)*n^4+(11/48)*n^5+(1/48)*n^6
eval(eqn1, [n = 4])
Download Q_10-10-22_gentrate_eqn.mw
