Question: Using greek letters in menues, such as the "Enter Unit" menu
I have been trying to figure this out for a long time and can't find anyone else having the same problem.
I use the built-in unit system for assigned values (short-cut is Ctrl+Shift+u) a lot when doing electronics calculations and electromagnetism, so I often use resistances and therefore need to use Ohm. This is very often an option in the "Choose Unit" drop-down menu on the right, but when too many units are brought into the same calculation the option dissappear. Usually I the go to the "Enter Unit" menu as to write the unit out myself I cannot figure out a way for it to accept greek letters. Does anyone know what to do?
