Question: Maple error when using {} as assuming. Error, (in convert/multiset) too many levels of recursion
in my program, I keep assumptions in a set. Sometimes this is empty if no assumptions are used. This never caused a problem before (at least I do not think so, else I would have seen it) when using empty {} in assuming, except for now.
Here is one example below. Is this a known problem? I noticed when changing {} to [] the error goes away. I am not sure why, and if this is known issue. But will change from a set to a list to avoid this.
Maple 2022.2 on windows 10
`Standard Worksheet Interface, Maple 2022.2, Windows 10, October 23 2022 Build ID 1657361`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1392 and is the same as the version installed in this computer, created 2023, February 13, 12:58 hours Pacific Time.`
ode:=diff(diff(y(x),x),x)+diff(y(x),x)^2+diff(y(x),x) = 0;
ic:=y(0) = 0;
sol:=y(x) = -ln(exp(x))+ln(-1+_C1*exp(x))-ln(-1+_C1);
diff(diff(y(x), x), x)+(diff(y(x), x))^2+diff(y(x), x) = 0
y(0) = 0
odetest(sol,[ode,ic]) assuming {};
odetest(sol,[ode,ic]) assuming [];
[0, 0]
odetest(sol,[ode, ic]);
[0, 0]
Download feb_14_2023.mw
