Question: Why no warning is returned with 2D input?
Update: In Maple 2023 the warning appears with 2D. (Deleted because not reproducible on a different PC)
With 1D
int(1/(sqrt(x__0 - x)*sqrt(-x^2 + 1)), x = 0 .. x__0)
Warning, unable to determine if -1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
Warning, unable to determine if 1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0)
With 2D
int(1/(sqrt(x__0-x)*sqrt(-x^2+1)), x = 0 .. x__0)
The root cause might be the same as for this open question.
int_warning_2D.mw
int_warning_1D.mw
