Question: Error, (in convert/parfrac) cannot convert to partial fraction form V2023
Is this something known or should be fixed? I check it is exists also in V 2022 for same input.
expr:=40/9*(43/32*2^(1/3)*(2*exp(16*c[2])*y^15-46/43*exp(11*c[2])*y^10+1/86*exp(6*c[2
])*y^5)*y*16^(2/3)*(exp(c[2])^7*y^7)^(2/3)-5/4*2^(2/3)*(2*exp(20*c[2])*y^20-169
/40*exp(15*c[2])*y^15+1/5*exp(10*c[2])*y^10)*16^(1/3)*(exp(c[2])^7*y^7)^(1/3)+(
2*exp(24*c[2])*y^20-53/2*exp(19*c[2])*y^15+17/4*exp(14*c[2])*y^10)*y^4)*exp(3*c
[2])/y^3/exp(5*c[2])/(1/9*(-1/4-exp(10*c[2])*y^10+8*exp(5*c[2])*y^5)*16^(2/3)*(
exp(c[2])^7*y^7)^(2/3)+(-2/3*(11/4*exp(9*c[2])*y^5-1/2*exp(4*c[2]))*2^(1/3)*y*
16^(1/3)*(exp(c[2])^7*y^7)^(1/3)+2^(2/3)*(2*exp(13*c[2])*y^10-2*exp(8*c[2])*y^5
))*y^3)/(-3/8*2^(2/3)*16^(2/3)*(exp(c[2])^7*y^7)^(2/3)*exp(c[2])*y+(exp(5*c[2])
*y^5-1/4)*16^(1/3)*(exp(c[2])^7*y^7)^(1/3)+3/2*2^(1/3)*exp(4*c[2])*y^4):
int(expr,y);
But for some reason I do not now understand, I am able to actually trap this error, which makes it much less serious for me, as the program can continue.
In all other cases where Maple generated such internal exceptions, it was not cought by try/catch.
So I am able to bypass this problem, but thought to check if someone can shed more light on this and why it happens.
interface(version)
`Standard Worksheet Interface, Maple 2023.0, Windows 10, March 6 2023 Build ID 1689885`
interface(warnlevel=4);
kernelopts('assertlevel'=2):
3
*y^5-1/4)*16^(1/3)*(exp(c[2])^7*y^7)^(1/3)+3/2*2^(1/3)*exp(4*c[2])*y^4);
(40/9)*((43/32)*2^(1/3)*(2*exp(16*c[2])*y^15-(46/43)*exp(11*c[2])*y^10+(1/86)*exp(6*c[2])*y^5)*y*16^(2/3)*((exp(c[2]))^7*y^7)^(2/3)-(5/4)*2^(2/3)*(2*exp(20*c[2])*y^20-(169/40)*exp(15*c[2])*y^15+(1/5)*exp(10*c[2])*y^10)*16^(1/3)*((exp(c[2]))^7*y^7)^(1/3)+(2*exp(24*c[2])*y^20-(53/2)*exp(19*c[2])*y^15+(17/4)*exp(14*c[2])*y^10)*y^4)*exp(3*c[2])/(y^3*exp(5*c[2])*((1/9)*(-1/4-exp(10*c[2])*y^10+8*exp(5*c[2])*y^5)*16^(2/3)*((exp(c[2]))^7*y^7)^(2/3)+(-(2/3)*((11/4)*exp(9*c[2])*y^5-(1/2)*exp(4*c[2]))*2^(1/3)*y*16^(1/3)*((exp(c[2]))^7*y^7)^(1/3)+2^(2/3)*(2*exp(13*c[2])*y^10-2*exp(8*c[2])*y^5))*y^3)*(-(3/8)*2^(2/3)*16^(2/3)*((exp(c[2]))^7*y^7)^(2/3)*exp(c[2])*y+(exp(5*c[2])*y^5-1/4)*16^(1/3)*((exp(c[2]))^7*y^7)^(1/3)+(3/2)*2^(1/3)*exp(4*c[2])*y^4))
try
   int(expr,y);
catch:
   print("error");
end try;
"error"
int(expr,y);
int(simplify(expr),y);
Download int_error_may_29_2023.mw
