Question: Error, (in SolveTools:-Polynomial) too many levels of recursion when using alias
I found another big problem.
In 2022, I get Error, (in SolveTools:-Polynomial) too many levels of recursion when using alias(seq(c[k] = _C||k, k = 0..10)); at the top of my code and the solution to the ode has c[2],c[3] etc.. as constants of integration.
This solution was given by Kitonum in this answer
I had this for years in the code (i.e. the alias) code.
In Maple 2022 the following gives the above exception error from odetest. I am using 2022, because in 2023 it just hangs on the same code.
If I remove the alias code, no error shows. (solution is wrong, but that is different story).
Also, If I remove the alias code, 2023 no long hangs!
#kernelopts('assertlevel'=2):
c[0], c[1], c[2], c[3], c[4], c[5], c[6], c[7], c[8], c[9], c[10]
ode:=diff(diff(y(x),x),x)+4*diff(y(x),x)+12*y(x) = 80*sin(2*x);
sol:=y(x) = -10*exp(-1/2*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*((-1/10*exp(4*I*2^(1/2)*x)+1/10)*c[2]-1/10*I*c[3]*exp(4*I*2^(1/2)*x)-1/10*I*c[3])/((exp(4*I*2^(1/2)*x)-1)*c[2]+I*c[3]*exp(4*I*2^(1/2)*x)+I*c[3])*c[1]-10*I*exp(-1/2*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*(cos(2*x)-sin(2*x))*exp(2*I*2^(1/2)*x)*exp(2*I*2^(1/2)*x)^(-1/2*I*2^(1/2))/((exp(4*I*2^(1/2)*x)-1)*c[2]+I*c[3]*exp(4*I*2^(1/2)*x)+I*c[3]);
odetest(sol,ode);
diff(diff(y(x), x), x)+4*(diff(y(x), x))+12*y(x) = 80*sin(2*x)
y(x) = -10*exp(-(1/2)*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*((-(1/10)*exp((4*I)*2^(1/2)*x)+1/10)*c[2]-((1/10)*I)*c[3]*exp((4*I)*2^(1/2)*x)-((1/10)*I)*c[3])*c[1]/((exp((4*I)*2^(1/2)*x)-1)*c[2]+I*c[3]*exp((4*I)*2^(1/2)*x)+I*c[3])-(10*I)*exp(-(1/2)*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*(cos(2*x)-sin(2*x))*exp((2*I)*2^(1/2)*x)*(exp((2*I)*2^(1/2)*x))^(-((1/2)*I)*2^(1/2))/((exp((4*I)*2^(1/2)*x)-1)*c[2]+I*c[3]*exp((4*I)*2^(1/2)*x)+I*c[3])
Download odetest_error_june_15_2023.mw
Why using the alias line above causes this error?  If you remove the alias line, you will see it completes with no error.
But it hangs in 2023. I am no longer using 2023 but went back to 2022 due to too many hangs in 2023. I wonder now if it because of this alias line I had there all the time.  I will remove now and see if this solves some of the hangs I had in 2023.
Anyone can shed some more light on what is going on?
Windows 10.
