Question: How do I test against the specified tolerance?
Good day everyone.
I am trying to write a code with variable stepsize involving tolerance. two vectors are declare for the errors. However, I don't know how to declare the two errors in comparison with the tolerance. Please kindly help. Also, any other modification to the entire code is also welcomed. Thank you all and best regards.
The code is as attached.
Variable_step_size_Falkner.mw
