Question: CodeTools[Profile] --Can't get it to work
I'm trying to use CodeTools[Profile] to investigate my memory leak and the effect or lack there of of 'forget' to improve it.
I copied my code from an example:
with(CodeTools[Profiling]);
 [Allow, Build, Coverage, GetProfileTable, Ignore, IsProfiled,
   LoadProfiles, Merge, PrintProfiles, Profile, Remove,
   SaveProfiles, Select, SortBy, UnProfile]
Profile([PickAngles(1.0, 1.0, 1.0)]);
Error, (in CodeTools:-Profiling:-Profile) unexpected argument(s)
The 'unexpected argument' is the 'result' from 'PickAngles'. I've tried with and w/o the '[]' but it does the same thing failing to recognize that 'PickAngles' is a procedure.
The example I used is here:
https://www.maplesoft.com/support/help/maple/view.aspx?path=CodeTools%2FProfiling%2FProfile procedure.
I did what to make of the subscript Profiles in the example so I used '[Profiles]' and that worked or seemed to.
