Question: Has anybody had this strange error: Maple does not start. A fatal error is detected by Java RE.
Both, Maple and MapleSim in Versions from 2021 to 2023 do not start. A logfile is saved which starts as
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000000000000, pid=17256, tid=10520
# JRE version: OpenJDK Runtime Environment Temurin-19.0.1+10 (19.0.1+10) (build 19.0.1+10)
# Java VM: OpenJDK 64-Bit Server VM Temurin-19.0.1+10 (19.0.1+10, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, windows-amd64)
# Problematic frame:
# C  0x0000000000000000
This only occurs when the notebook (on which the error occurs) is connected to the domain network. If the notebook is not connected, Maple and MapleSim can be started and will continue to run when the network is reconnected.
Has anybody seen this before or any ideas what this could be?
Edit: This all happened under Windows 10 on a notebook that has been running Maple for 3 years and only recently displayed this error.
Edit2: Connection via an USB doc which also connects to an external monitor.
