Question: Remove unit symbol?
Is there a way to remove a unit symbol?  "AddUnit" allows to add additional symbols or change the default symbol, but I don't see any way to remove symbols?
A good example is for the hectare.  Maple 2023 uses "a" as the default symbol for the are, except that the unit symbol "a" does not allow using SI prefixes because the peta- unit prefix then conflicts with the pascal ("Pa").  I can use "AddUnit" to change the default symbol for the are from "a" to "are" but I still cannot enable SI prefixes unless the symbol "a" is removed from the symbol set.  This way hectares ("hare") and petares ("Pare") can be used.
I don't see a way to nondestructively/temporarily delete units either ("RemoveUnit").  Deleting the unit "are" and then recreating it as a new unit with the symbol "are" would solve the same problem.
I just saw that there already exists a separate "hectare" unit with the symbol "ha" which presumably also needs to be removed in order to enable SI prefixes for "are".  This is just one example but a general way to remove units and/or unit symbols should be very helpful.
