Question: on solution to ode using Laplace transform when RHS is Dirac
I was trying this ode with Maple
Do you agree this solution is not correct by Maple?
ode:=diff(y(t),t)+y(t)=Dirac(t);
ic:=y(0)=1;
sol:=dsolve([ode,ic],y(t),method='laplace');
It gives  y(t) = 2*exp(-t)
But from the discussion in the above link we see this is wrong solution. Maple also does not verify it:
odetest(sol,[ode,y(0)=1])
[-Dirac(t), -1]
Would this be considered a bug I should report or not? Note this result is only when using Laplace method. The default method gives better solution.
ic:=y(0)=1;
sol:=dsolve([ode,ic],y(t));
Maple 2023.2.1
