Question: is this correct to solve the implicit fractional differential equations using 4th order Runge-Kutta Method
with(Student[NumericalAnalysis]);
with(plots);
with(DEtools);
f := proc(u, r) local res; res := 1/25*r^2 + (sin(u(r)) + sin(diff(u(r), [r $ 1/5])))/(r^2 + 47); return res; end proc;
RK4 := proc(f, u0, r0, h, n) local u, r, i, k1, k2, k3, k4; u := Vector(n + 1); r := Vector(n + 1); u[1] := u0; r[1] := r0; for i to n do k1 := f(u[i], t[i]); k2 := f(u[i] + 1/2*h*k1, r[i] + 1/2*h); k3 := f(u[i] + 1/2*h*k2, r[i] + 1/2*h); k4 := f(u[i] + h*k3, r[i] + h); u[i + 1] := u[i] + 1/6*h*(k1 + 2*k2 + 2*k3 + k4); r[i + 1] := r[i] + h; end do; return [u, r]; end proc;
RK4 := proc (f, u0, r0, h, n) local u, r, i, k1, k2, k3, k4; u
   := Vector(n+1); r := Vector(n+1); u[1] := u0; r[1] := r0;
   for i to n do k1 := f(u[i], t[i]); k2 := f(u[i]+(1/2)*h*k1,
   r[i]+(1/2)*h); k3 := f(u[i]+(1/2)*h*k2, r[i]+(1/2)*h); k4 :=
   f(u[i]+h*k3, r[i]+h); u[i+1] := u[i]+(1/6)*h*(k1+2*k2+2*k3+k4\
  ); r[i+1] := r[i]+h end do; return [u, r] end proc
u0 := cos(abs(0.9))/15;
                      u0 := 0.04144066455
r0 := 0;
                            r0 := 0
h := 0.1;
                            h := 0.1
n := 100;
                            n := 100
solution := RK4(f, u0, r0, h, n)
u := solution[1];
r := solution[2];
plot(u, r, style = line, color = blue, labels = ["Time (r)", "Solution (u)"]);
 is this correct to solve the implicit fractional differential equations using 4th order Runge-Kutta Method. will fsolve command  solve the fractional differential equations ?
