Question: Error, (in Typesetting:-Parse) too many levels of recursion converting output of ODEsteps to latex
I found that sometimes Maple gives
When using the Latex command on the output of Student:-ODEs:-ODESteps
Below is worksheet showing it works for some and gives error for others. Is there a workaround for this? I'd like to convert the steps to Latex.
This happens in worksheet using either Display->Typesetting level as EXTENDED or STANDARD
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1722 and is the same as the version installed in this computer, created 2024, April 12, 17:58 hours Pacific Time.`
ode:=diff(y(x),x)=0;
the_output:=Student:-ODEs:-ODESteps(ode,y(x)):
latex(the_output)
diff(y(x), x) = 0
\begin{array}{ccc}
 & {} & \textrm{Let's solve}
 {} & {} & \frac{d}{d x}y \! \left(x \right)=0
 \textrm{•} & {} & \textrm{Highest derivative means the order of the ODE is}1
 \textrm{•} & {} & \textrm{Integrate both sides with respect to}x
 {} & {} & \int \left(\frac{d}{d x}y \! \left(x \right)\right)d x =\int 0d x +\mathit{C1}
 \textrm{•} & {} & \textrm{Evaluate integral}
 {} & {} & y \! \left(x \right)=\mathit{C1}
 \textrm{•} & {} & \textrm{Solve for}y \! \left(x \right)
\end{array}
ode := diff(y(x), x, x, x ) + 3*diff(y(x), x, x) + 4*diff(y(x), x) + 2*y(x) = 0;
latex(the_output)
diff(diff(diff(y(x), x), x), x)+3*(diff(diff(y(x), x), x))+4*(diff(y(x), x))+2*y(x) = 0
Download latex_error_ODE_steps_maple_2024_april_13_2024.mw
update: Reported to Maplesoft support.
