Question: why this patmatch fails inside proc but works outside?
I can't figure this out. Same exact patmatch works in global worksheet. But fails inside a proc.
I am using same exact code. In proc, I am doing    a::anything where `a` is now local symbol ofcourse. In worksheet, it is global ofcourse. I make sure I clear `a` in worksheet each time also.
So why it pathmatch fail in the proc? I must be doing something wrong but do not see it.,
26148
a:='a':
stat:=0^n:
if patmatch(stat,0^a::anything) then
     0;
  else
     stat;
  fi;
foo:=proc(stat)
  local a;
     0;
  else
     stat;
  fi;
#why this does not return zero as expected?
foo(stat)
0^n
Here is screen shot in debugger showing patmatch failed inside the proc
Very strange. What do I need to change in the proc to make it work as in worksheet?
Download patmatch_in_proc.mw
