Question: What is the difference between m[f] and m:-f where module m exports a name f (assigned and unassigned cases)?
I am reading the Maple Programming Guide chapter 3 "Maple Expressions". There are subsections on "Indexed Expressions" and "Member Selection".
The following is based on reading these sections.
Consider the following module definition
m := module() export e, f:=2; end module:
What is the difference between m[e] and m:-e or m[f] and m:-f?
The documentation says that both evaluate module m's export e but the difference is that the index selection form will evaluate e before resolving the export.
What does this mean exactly?
When I try out in a worksheet both m[f] and m:-f return 2 and m[e] and m:-e return the name e.
