Question: Integration change of variables. How to tell Maple what the new integration variable should be?
What is the correct syntax in Maple to do integration of variables on
So that the new integration variable is using the mapping    u=y*x^(1/3) so that the result is
The problems seems is that there is no option to tell Maple what the new integration variable is. So it does not know it should be y or x?
I looked at help and all my tries failed. Below is worksheet and also examples from another software as reference. The other software has argument to tell change of variable what is the new integration variable should be. But in Maple, there is no such option.,  Does this mean in Maple change of integration variables only works when the right hand side of the transformation has only one symbol and not two or more? i.e. this works   u=y, but not u=y*x
T:=Student:-MultivariateCalculus;
e:=Int(1/(3*u^4 + u + 3),u);
T:-ChangeOfVariables(e,[u=y*x^(1/3)]);
T:-ChangeOfVariables(e,[y=u*x^(-1/3)]);
Int(1/(3*u^4+u+3), u)
Error, (in Student:-MultivariateCalculus:-ChangeOfVariables) unable to complete the change-of-variables operation
Student[Calculus1][IntTutor](); #did not help either
Download change_of_variables_integration_august_31_2024.mw
I searched help and see nothing specific to change of variable for integration, so I assumed the above is the command to use. Am I using the wrong command for integration change of variables in Maple?
For reference, I need to duplicate this in Maple:
