Question: least square curve fitting
can someone help me curve fitting these parameeters...i only got 1 for all of this 90As4.mw
with(Statistics)with(plots)with(Optimization)with(LinearAlgebra)
E[1] := 126*10^9E[2] := 11*10^9G[12] := 6.6*10^9G_0__12 := 10.1*10^9nu[12] := .28E_0__2 := 15.5*10^9
true_strain := [0, .406915, .710106, .989362, 1.28457, 1.53989, 1.86702, 2.21011, 2.625, 2.99202]; true_stress := [0, 46.0227*10^6, 81.8182*10^6, 109.091*10^6, 138.068*10^6, 163.636*10^6, 194.318*10^6, 219.886*10^6, 248.864*10^6, 267.614*10^6]; epsilon_dot := 10^(-4)
sigma_t := map(proc (epsilon) options operator, arrow; E[instantaneous]*(1-lambda[90*deg]*epsilon*(sum(P[i], i = 1 .. 10)-(sum(P[i]*exp(lambda[i]*epsilon/epsilon_dot), i = 1 .. 10)))/epsilon_dot)*epsilon end proc, true_strain)
obj := sum((sigma_t[i]-true_stress[i])^2, i = 1 .. 10)
indets(obj, name)
{E[instantaneous], P[1], P[2], P[3], P[4], P[5], P[6], P[7], P[8], P[9], P[10], lambda[1], lambda[2], lambda[3], lambda[4], lambda[5], lambda[6], lambda[7], lambda[8], lambda[9], lambda[10], lambda[90*deg]}
Optimization[Interactive](obj)
The solution was obtained with the following warning:
  no iterations performed as initial point satisfies first-order conditions
[Float(infinity), [E[instantaneous] = HFloat(1.0), P[1] = HFloat(1.0), P[2] = HFloat(1.0), P[3] = HFloat(1.0), P[4] = HFloat(1.0), P[5] = HFloat(1.0), P[6] = HFloat(1.0), P[7] = HFloat(1.0), P[8] = HFloat(1.0), P[9] = HFloat(1.0), P[10] = HFloat(1.0), lambda[1] = HFloat(1.0), lambda[2] = HFloat(1.0), lambda[3] = HFloat(1.0), lambda[4] = HFloat(1.0), lambda[5] = HFloat(1.0), lambda[6] = HFloat(1.0), lambda[7] = HFloat(1.0), lambda[8] = HFloat(1.0), lambda[9] = HFloat(1.0), lambda[10] = HFloat(1.0), lambda[90*deg] = HFloat(1.0)]]
Download 90As4.mw
