Question: dsolve gets stuck
dsolve gets stuck on a problem. Attached is the worksheet.
In Case I, dsolve solves the two ODEs separately. In Case II, dsolve solves them together, but only if I define a constant. In Case III the constant is not defined. dsolve never returns, and I have to hit the stop sign. The question I have: Is there a consistent method to the failure so that I can avoid the problem in the future with other ODEs?
dsolve_bug.mw
