Question: questions about mapole
Hello sir, how are you?
Sorry to bother you, I needed your help. I have the script from your textbook "3D Graph Equation of Motorcycle run on Maple Software". It's not working. I'd appreciate it if you could take a look.
with(plots);
implicitplot3d(((49.80*x + 19.44*y + 133.2300 - 19.08*sqrt(x^2 + 8.30*x + 19.8469 + y^2 + 3.24*y) - 66.6150*abs(-3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42) + 0.5625*abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2) = ((((((((((((2 + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(y^2 + 3.24)) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 3.24) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(y^2 - 3.18)) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 8.30) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 3.24)) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(y^2 + 3.24) + 0.42*abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2) and ((((((((((((2 + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(y^2 + 3.24)) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 3.24) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(y^2 - 3.18)) + abs(3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2))) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(x^2 + 8.30) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42) + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 8.30) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y - 2)*(x^2 + 3.24)) - 3.9*sqrt((x - 1.7)^2 + (y - 1.35)^2)) + 0.42 + abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2)*(y^2 + 3.24) + 0.42*abs(0.00390625*(x^8 + y^8) - 0.5*x + 2*y + 2) = 0, x = -7 .. 7, y = -4 .. 3, z = -3 .. 3, numpoints = 350000, style = surface, color = "Niagara Azure");
