Question: Bug report. Setting extended interface causes internal bug from typesetting
In Latest Maple 2024.2, I found that when doing z:=%  where % is result on integration, causes internal error
          Error, unexpected result from Typesetting
But when the interface is set to standard, no such error.
This not only happen in worksheet, but also when code is run in command line!
Worksheet below.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1837 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
Example using extended
interface(typesetting=extended):
int(exp(-int(b(t),t))*t^4*csc(t)^2,t);
int(exp(-(int(b(t), t)))*t^4*csc(t)^2, t)
z:=%;
Error, (in Risch:-Norman) too many levels of recursion
Example using standard
interface(typesetting=standard):
z:=%;
Example using direct assignment also
z:=int(exp(-int(b(t),t))*t^4*csc(t)^2,t);
Download extended_interface_causes_internal_bug_dec_13_2024.mw
ps. also reported to Maple support
