Question: Error, (in dsolve) type `System` does not exist when using dsolve inside threads.
I am trying to see if I can get speed up by using dsolve inside thread.
I made very simple example of global list of two differential equations to start with.
Next, created two threads where each picks one ode from the global list to process. So they should in theory run in parallel. The list of ode's is a global list in the worksheet for now.
But I keep getting error when calling dsolve
I tried also passing the actual ode to the thread, still, same error.
Next, I did not pass anything, but called dsolve directly from inside thread proc on same ode. The ode is local variable inside the proc. I still get same error.
                        Does this mean dsolve is not supported by threads?
But when I searched this subject, AI says it works in threads:
Everything works OK when I run dsolve in worksheet outside thread (i.e. normally).
I will show below worksheet showing these cases. I must not be doing something right. But what? Can one not pass data from global worksheet to the thread this way? Or does one needs to load something in each thread to make this work?
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1840 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
libname;
Example 1. Passing index of list to thread
g_list:=[sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0,
         diff(y(x),x)=lambda*sin(lambda*x)*y(x)^2+a*cos(lambda*x)^n*y(x)-a*cos(lambda*x)^(n-1)]:
work_func:=proc(i::posint)
  :-dsolve(g_list[i]):
Threads:-Wait(  seq( Threads:-Create( work_func(i)), i=1..2) );
Example 2. Passing actual ode itself to thread
work_func:=proc(ode::`=`)
  :-dsolve(ode):
Threads:-Wait(  seq( Threads:-Create( work_func(g_list[i])), i=1..2) );
Example 3. Normal processing. No threads
  :-dsolve(ode):
for item in g_list do
    work_func(item);
od:
#no error
Example 4. do not pass anything. Just call dsolve
  local x,t;
  local ode:=sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0;
  :-dsolve(ode):
Download error_dsolve_using_threads_dec_26_2024.mw
