Question: Grid:-Setup(numnodes=4) question
in help for Grid:-Wait, it has an example where it says
And in help for Grid:-Setup it says
"The numnodes option allows you to specify the number of nodes to be used in subsequent computations.  This option is only available in "local" mode."
Is numnodes supposed to be the same as number of cores on my PC?  If so, then why numnodes=4 says this will insure it run run on 2 core machine?
Is this typo and it should be 4 core machine?
