Question: Reduced Involutive Form
Dear Maple Community,
I come to you with a question about the reduced involutive form (rif) package. Namely, I decided to try the classic example from the "LONG GUIDE TO THE STANDARD FORM PACKAGE", which dates back to 1993. Here is the link to the complete documentation:
https://wayback.cecm.sfu.ca/~wittkopf/files/standard_manual.txt
So, the example is the following:
2.1 SIMPLE EXAMPLES
EXAMPLE A
Consider the system of nonlinear PDEs:
y Zxxx - x Zxyy  =  Zyy - y Zy
                        2     2    2
2 y x Zxxx Zxyy + x Zxxx + x y Zxyy  =  0
                  2    2
y Zxyy - x W + 2 x  y Z  =  0
                 2    2
Zyy - y Zy  + 2 x  y W  =  x W
where the dependent variables W and Z are functions of the
independent variables x and y, and Zxxx denotes the third partial
derivative of Z with respect to x etc.
After making computations back in 1993 with Maple V, they obtain the following involutive form:
In our original notation the (considerably) simplified system is:
                                            2
  Zxxx = 0, Zxy = 0, Zyy = y Zy, W = 2 x y Z
So, I tried the same system of PDEs in the modern Maple and the modern rifsimp() command. You can find the result below:
I demo_question.mw
The problem is that nowadays [Maple 2022.1] , I get only the trivial solution: z = 0 and w = 0.
Could someone clarify, please, where the truth is and what am I doing wrong?
Thanks a lot in advance for any help and clarification!
Best regards,
Dr. Denys D.
with(DETools):
PDE1 := y*diff(z(x,y), x$3) - x*diff(z(x,y),x,y$2) = diff(z(x,y),y$2) - y*diff(z(x,y), y);
y*(diff(diff(diff(z(x, y), x), x), x))-x*(diff(diff(diff(z(x, y), x), y), y)) = diff(diff(z(x, y), y), y)-y*(diff(z(x, y), y))
PDE2 := 2*x*y*diff(z(x,y),x$3)*diff(z(x,y),x,y$2) + x*(diff(z(x,y),x$3))^2 + x*y^2*(diff(z(x,y),x,y$2))^2 = 0;
2*x*y*(diff(diff(diff(z(x, y), x), x), x))*(diff(diff(diff(z(x, y), x), y), y))+x*(diff(diff(diff(z(x, y), x), x), x))^2+x*y^2*(diff(diff(diff(z(x, y), x), y), y))^2 = 0
PDE3 := y*diff(z(x,y),x,y$2) - x*w(x,y) + 2*x^2*y*z(x,y)^2 = 0;
y*(diff(diff(diff(z(x, y), x), y), y))-x*w(x, y)+2*x^2*y*z(x, y)^2 = 0
PDE4 := diff(z(x,y), y$2) - y*diff(z(x,y),y) + 2*x^2*y*w(x,y)^2 = x*w(x,y);
diff(diff(z(x, y), y), y)-y*(diff(z(x, y), y))+2*x^2*y*w(x, y)^2 = x*w(x, y)
sys := [PDE1, PDE2, PDE3, PDE4]:
rif := rifsimp(sys, [[w], [z]], indep = [x,y]);
table( [( Case ) = [[z(x, y)*(8*z(x, y)^2*y^2*x^2-1) = 0, diff(z(x, y), x), "false split"]], ( Solved ) = [w(x, y) = 0, z(x, y) = 0] ] )
